akshay karambale
Removal of Pre-requisite Welcome
We have created one bootstrapper with some pre-requisite. As per the way you suggested us we have able to remove the prereuisteDlg (i.e by using 1=2). Now we want to remove that WelcomeprereqDlg also. Can you please help us to remove it. We are waiting for your reply
Thanks and Regards
Akshay
Re: Removal of Pre-requisite Welcome
Hello Akshay,
Unfortunately, it is not possible to hide that dialog, at least not in the same way as we hid the "PrerequisitesDlg".
In order to 'hide' the "WelcomePrereqDlg" dialog, please go to "Table Editor" --> "BootstrapperUISequence" --> condition the "WelcomePrereqDlg" action.
akshay karambale
Thanks for reply, i have checked the Table Editor i found "AI_BOOTSTRAPPER AND (NOT AI_BOOTSTRAPPER_RESUME) AND AI_MISSING_PREREQS" this condition in condition collumn of WelcomePrereqDlg. But actually i am not getting what should be the actual condition to hide that WelcomePrereqDlg from user. Can you please help me to solve this. I have attached the screen shot of table editor you can go through it.
Thanks and Regards
Akshay
Hello Akshay,
The condition used here, as you have used for the other dialog, should be a condition that is always evaluated as false.
For instance, beside the already existing condition, you could add the following:
AND 1=2
This should prevent the dialog from being shown.
