KhMi
Exe and MSI
I have 2 build configuration in my installer project, Default (EXE) and MSI configurations.
I wonder if it is possible to set it up in a way that:
* If the installation used was the EXE, some files will be downloaded from a link
* If the installation used was the MSI, those same files will be included in the package, therefore, no download is needed.
It should result into:
* the MSI inside the EXE should NOT contain the files
* while the standalone MSI contains the files, so that the files will be available for those who are behind some sort of an internet proxy.
Is there a way to do this inside a single installer project?
Re: Exe and MSI
If I understand your scenario correctly, you want to download the files only if the setup used is of .EXE type. To do so, you can add a new "File Download" operation in the "Files and Folders" page and condition it as it follows:
SETUPEXEDIR
THe above property is a property that is set only when a .EXE setup is used, therefore the operation should only run when the .EXE setup is ran.
KhMi
Re: Exe and MSI
Thanks for the reply!
Is there also a way to differentiate between MSI build configurations? For example, if I have 3 build configurations:
* BuildExe
* BuildMSI_Download
* BuildMSI_ContainsFiles
With the the configurations, only the 3rd configuration will contain the files and the above two should still download the needed files.
Kind Regards,
Khalid
KhMi
Re: Exe and MSI
To further clarify:
The BuildExe and BuildMSI_Download build configurations does not have a copy of the files, but instead, needs to download it from a server.
While BuildMSI_ContainsFiles contains (within the package) those files, and therefor, no longer need to download them.
QUESTION: Is there a way to configure a project so that one msi installer contains 50% files and 50% downloaded during installation, while the other msi contains 100% of the files? Resulting to one msi "doubly" bigger than the other?
Kind Regards,
Khalid
Re: Exe and MSI
First of all, please accept my apologies for such a delayed reply (I was off for a week).
In what regards your question, unfortunately it is not possible to "distinguish" between two .MSI packages.
However, here is how we can proceed.
We can add, in the MSI build where you want to download the files, a dummy feature that will condition the execution of the "File download" operation. We can then include this feature only in the build that will need to download the resources.
Basically, the operation should only be executed if the feature is to be installed. Since the feature will exist in only one build, then the operation will only execute in that build.
Hope this will help.
KhMi
Re: Exe and MSI
Thanks a lot, We have already arrived in the same conclusion and is in the process of integrating it to our solution.
By confirming that we are in the correct track boosts our confidence to continue, thanks :D
Kind Regards,
Khalid
Re: Exe and MSI
You are always welcome, Khalid!
I am glad I was able to help. :D
