m2i7c9k
Import Visual Studio Project Exception calling
Hi Guys,
I'm new for Advanced Installer, be gentle to me, please :) I have VSTO Add-in Word Document (2019 Off.Pro) and Visual Studio 2019 (1.6.7.532.28833).
I'd like to create the setup for my project, I tried (step by step: https://www.advancedinstaller.com/user- ... addin.html)
but I stuck on step 5.
https://uloz.to/file/awXBDwyYYOK7/err-advinst-png.
with error: Exception calling ".ctor" with "1" arguments(s):"Could not load file or assembly'System.Runtime.CompilerService.Unsafe, Version=4.0.1.1,Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependecies. The system cannot find the file specified".
So a tried another way files from loc. on hdd), it worked, but after opening my doc-level customization showed err. "the manifest may not be valid or the file could not be opened"....
Uf, is it horror. app for 500$ and doesn't work? I used OneClick install and everything went well.
I missed something, or I did something wrong?
Please is there some step by step latest guide for VSTO Office 2019 and VS 2019?
Thanks a lot
Mick
Re: Import Visual Studio Project Exception calling
Hello Mick and welcome to Advanced Installer forums,
Unfortunately, I can not say for sure why this happens.
In order for me to further investigate this, could you please forward me your VS solution (SLN file) and all of the project files it includes (only the project definition files without the source code files)? You can send these files by e-mail at support at advancedinstaller dot com.
stephend3g
Hi Caitlin,
I am also getting this error. It started occurring when I upgraded from Advanced Installer 17.2 to 17.4. Is it possible that 17.4 broke importing VSTO projects?
davidjpp
Contact: Website Twitter
I have just tried this with a Visio VSTO add-in in VS 2019, since it is supposed to be supported since AI 17.3. Unfortunately, I am getting the same error as the previous users....
David J Parker,
Microsoft MVP (Visio)
blog.bvisual.net
During our investigation we found that it is caused by the latest Visual Studio (16.7) update. We tried to implement a fix by ourselves, but it seems that the only option we have is to submit this to Microsoft and ask them for a fix.
In the meantime, can you register the assemblies below to the GAC and see if it works for you?
gacutil -i "C:\Program Files\dotnet\sdk\3.1.401\Sdks\Microsoft.NET.Sdk.WindowsDesktop\tools\net472\System.Runtime.CompilerServices.Unsafe.dll"
gacutil -i "C:\Program Files\dotnet\sdk\3.1.401\Sdks\Microsoft.NET.Sdk.WindowsDesktop\tools\net472\System.Numerics.Vectors.dll"
This workaround worked for us. Please let us know if it helped you, too.
qwertyess
Hello;
Unfortunately did not work for me, even when I create new project.
C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.8 Tools>gacutil -i "C:\Program Files\dotnet\sdk\5.0.100-preview.8.20417.9\Sdks\Microsoft.NET.Sdk.WindowsDesktop\tools\net472\System.Runtime.CompilerServices.Unsafe.dll"
Microsoft (R) .NET Global Assembly Cache Utility.  Version 4.0.30319.0
Copyright (c) Microsoft Corporation.  All rights reserved.
Assembly successfully added to the cache
C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.8 Tools>gacutil -i "C:\Program Files\dotnet\sdk\5.0.100-preview.8.20417.9\Sdks\Microsoft.NET.Sdk.WindowsDesktop\tools\net472\System.Numerics.Vectors.dll"
Microsoft Visual Studio Enterprise 2019 Preview Version 16.8.0 Preview 2.1
Windows 10 64bit
Are you getting the exact same error as the users above?
If that is the case, could you please give me some more details about your scenario? I have tried reproducing it, but unfortunately I was not able to do so.
My colleague Eusebiu who investigated this issue more in depth was off for this week, therefore I am trying to continue this thread on his behalf.
If possible, could you please forward me your VS solution (SLN file) and all of the project files it includes (only the project definition files without the source code files)? You can send these files by e-mail at support at advancedinstaller dot com.
If you do not get the same error as above, could you please let me know which error message you are encountering?
qwertyess
yes the exact same error
As I mentioned before I get the error even with new VS project.
AdvancedInstallerTest.rar
(30.43 KiB) Downloaded 1606 times
Can you please download .NET Core 3.1.401, then install it, perform the registration of those two files again and see if it works?
qwertyess
It works great.
Thank you so much
C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.8 Tools>gacutil /f -i "C:\Program Files\dotnet\sdk\3.1.401\Sdks\Microsoft.NET.Sdk.WindowsDesktop\tools\net472\System.Runtime.CompilerServices.Unsafe.dll"
C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.8 Tools>gacutil /f -i "C:\Program Files\dotnet\sdk\3.1.401\Sdks\Microsoft.NET.Sdk.WindowsDesktop\tools\net472\System.Numerics.Vectors.dll"
We are glad everything is working as expected now!
chris
I have been struggling with the same problem for a while now and finally found a solution. More like a workaround.. I hope this may help others.
Instead of choosing from "Templates", i have selected "Generic Installer Project". From there i have added necessary project files and dll files into it and was able export an installer. I have no idea why i am getting an error from "Templates > Visual Studio Application". I never had that problem with previous versions.
Note: You must import every DLL file under "References". To find the right path of it, simply right click on the dll and select properties. You will see the path in the properties window.
Hello Chris and welcome to our forums,
Thank you for sharing your solution with us.
talha8018
I am new here I'm also getting this error on my latest advanced installer.
I am using visual studio 2019 as I also download and install following recommendation
Eusebiu wrote: ↑Tue Sep 22, 2020 10:41 am Hi,
Please note that my colleague also mentioned about registering those two DLLs.
Could you please follow the above steps and let me know if everything works as expected?
