istok20
set installation folder path from cmd...
How to set the custom installation folder path when running msi from cmd? (installdir, appdir parameters did not work)
Re: set installation folder path from cmd...
In order to set the installation folder from command line, the APPDIR property should be used.
Please note that the property should be passed as full capital letters (i.e. APPDIR not appdir or Appdir).
Additionally, no space characters should be inserted before and after the "=" character.
Working example:
APPDIR=C:\
Not working example:
APPDIR = C:\
For instance, the command line can look something as it follows:
