a.guelle
[solved] "Invalid URL format...." in OpenURL Action with dynamic properties
Hi Everyone,
Min. AI 16.3 - 17.3 does not allow properties in the Open URL action.
Angelo
a.guelle
Re: "Invalid URL format...." in OpenURL Action with dynamic properties
Can anyone from AI confirm the behaviour? This prevents us from using any version higher than AI 15.
Hi Angelo,
We investigated on this and indeed this seems to be an issue of our "Custom Actions" page UI. A fix for this issue will be available in a future version of our product, thank you for bringing it to our attention. When the fix will be released we will update this forum thread.
Until then, as a workaround, you can use our "Table Editor" feature (available only in our Enterprise and Architect edition of Advanced Installer).
Just go to "Table Editor" page and select the "CustomActions" table. Select the row of your OpenUrl action and set its "Target" column like this:
http://localhost:[HTTP_PORT_PROP]/centrax/...
Then save and rebuild your setup project.
Hope this helped.
This has been fixed in version 17.5 of Advanced Installer, released on September 22nd, 2020.
a.guelle
Works like a charme,
thank you for pushing this into the release.
Re: [solved] "Invalid URL format...." in OpenURL Action with dynamic properties
You are always welcome, Angelo!
I am glad everything works as expected now.
