baruchi
Cannot test Dialogs - Test panel is grayed out.
I created a template out of an installer project.
I then created a new project out of the template applied all the required modification and saved.
I can run the installer (I run it from Visual Studio) and even tried installing a product and it all went well.
However i am unable to use the "Test" buttons for the Dialogs - both are grayed out.
In the original project, the one I created the template from, there is not problem to use the "Test" buttons.
What can cause this?
Re: Cannot test Dialogs - Test panel is grayed out.
Hi and welcome to our forums,
I have tested the scenario but cannot replicate the issue. Could you send us by email at support at advancedinstaller dot com the .AIPs (setup project) files of your original setup and of the new setup project that manifests this behavior? So we can fully check and investigate on this?
