Resolution
lower case when edit xml
I need to edit one xml file attribute with user input from installer dialogs, and it should always replace with lower case.
how can convert to lower case during xml edit?
Re: lower case when edit xml
Hi and welcome to our forums.
In order to achieve this, you can use the "Process Data" custom action to convert the string introduced by the user to lower case. You can add this custom action above the "Add Resources" action group from the "Custom Actions" page with the configuration from the image below.
Convert to Lower Case.png (9.97 KiB) Viewed 2996 times
