dfmmalaw
Win32 error when opening Advanced Installer
After building my installer I am no longer able to open Advanced Installer without it immediately crashing. Can someone look at the attached images and let me know if they have any thoughts?
Re: Win32 error when opening Advanced Installer
Indeed, this seems to be a recent Advanced Installer issue that will be fixed very soon. In the meantime, please open the registry editor and remove the key below which should solve the problem:
HKEY_CURRENT_USER\Software\Caphyon\Advanced Installer\Settings\Account
If it still doesn't work, please let us know.
dfmmalaw
Thanks. Unfortunately it didn't work and I have uninstalled and installed multiple times without luck.
shwethag
I am also having the same problem. Are there any previous versions that we can install and work ? I have an urgent requirement to create an installation package. Please let me know.
Thank you,
Shwetha.
dfmmalaw
Got it working by restoring pc. Not sure what the issue was but at least I can go back to building. Thank you!
A new version of Advanced Installer (17.4.1) containing this fix, has already been released. Please download and install it in order to overcome this problem.
