roonz11
Set Update properties in Azure Pipeline
Hello Support,
I have a build task in my azure pipeline that creates a new update using the following command:
NewUpdate $(InstallerName)\$(InstallerName)_$(BuildPlatform)-SetupFiles\$(InstallerName)_$(BuildPlatform).exe -name $(UpdateName)_$(version) -display_name $(UpdateName) -url $(BlobUrl)
After examining the outputed txt file I noticed that the RegistryKey is wrong and Flags are missing.
I tried adding another AI build task where I use the /UpdateInstalledDetection in the command line however this resulted in the following error:
UpdateInstalledDetection $(UpdateName)_$(version) -detection_type RegKeySearch -path "HKLM\Software\WOW6432Node\$(Manufacturer)\$(Product)\Version" -expected_value $(version) -64bit
C:\hostedtoolcache\windows\advinst\17.4.0\x86\bin\x86\AdvancedInstaller.com /execute D:\a\1\s\Installer\Updater_x64.aip D:\a\_temp\202.aic
UpdateInstalledDetection Update_1.0.17.999 -detection_type RegKeySearch -path "HKLM\Software\WOW6432Node\Company\Product\Version" -expected_value 1.0.17.999 -64bit
Update not found
##[error]Failed to execute Advanced Installer task. Error: UpdateInstalledDetection Update_1.0.17.999 -detection_type RegKeySearch -path "HKLM\Software\WOW6432Node\Company\Product\Version" -expected_value 1.0.17.999 -64bit
Update not found
Can you please direct me on how I can achieve this? Can this all be done in one build step?
Thanks!
roonz11
Re: Set Update properties in Azure Pipeline
I was able to get it working with one build step and simply adding a '\n' character after each command.
UpdateInstaller ProductUpdate_$(version) -command_line "/qn" -no_elevation -install_silent
However, even though I have -no_elevation and -install_silent, they are not found in the outputed txt file.
I'm just wondering now how I can set the following properties as well?
- NoGUICommandLineSwitch = /exenoui /qn
- Flags = SilentInstall|Sys64|Advertises
Ex. updater.txt
top entry is from pipeline
second entry is from AdvancedInstaller UI
;aiu;
[Update_1.0.6.999]
Name = Product
ProductVersion = 1.0.6.999
URL = https://myinstaller.blob.core.windows.n ... er_x64.exe
Size = 76071370
ReleaseDate = 04/09/2020
SHA256 = 2B3C1EFA3BDFB04502330FA48CB4FE90EA23B10A4FF521122C72A0BA1A85FB1B
MD5 = 6aee2b16ab7a82d6781ef50dd2f1b3ec
ServerFileName = Installer_x64.exe
RegistryKey = HKLM\Software\WOW6432Node\Manufacturer\Product\Version
Version = 1.0.6.999
[Update]
Name = Product
ProductVersion = 1.0.0.0
Size = 76071370
Version = 1.0.0.0
Thanks!
The following options:
-install_silent
--> "Attempt to suppress GUI or console" option from the "Update Installer" tab
-no_elevation
--> "Install update without elevation" option from the "Update Installer" tab
-64_bit
--> "Use 64-bit registry location" option from the "Update Installed Detection" tab
should correspond in the output txt file to this:
If the target package is an .EXE and the "Install update without elevation" option is used, then the "No GUI command line switch" should correspond to:
When building the UpdatesConfigurationProject from the command line, are these options not added to the output txt file?
Could you please proceed as it follows and let me know the outcome?
- apply the changes, but do not build
- manually open the .AIP file
- check if those options were checked (i.e. for -install_silent --> the "Attempt to suppress GUI or console" option, etc.)
roonz11
As you can see from my command, I do have -install_silent and -no_elevation but it does not produce the "NoGUICommandLneSwith" nor "Flags".
Can you tell me exactly what my command should look like?
Please accept my apologies for such a delayed reply.
I have tested this and I can indeed confirm that, for some unknown reason, the option ("Install update without elevation") is not set properly when the command line ("-no_elevation") is used.
I will forward this to our development team for further investigations.
Until a fix will be availalbe, I am afraid that the only way would be to manually check the required options.
However, in what regards the "Flags", this looks like it should be working as expected.
This issue has been fixed in version 17.6 of Advanced Installer, released on October 22nd, 2020.
