Marco28
Advanced Installer build task in Azure DevOps fails with output folder specified
Since yesterday all our Advanced Installer Build tasks are failing when the Output Package folder is defined.
It fails with the statement that the Output folder cannot be found.
When we do not define the output folder it is working fine.
Looking at the error message it seems that the Output path is only taking the relative path and not the absolute one.
I have attached a screenshot of the error.
AI error.png (14.32 KiB) Viewed 10431 times
Re: Advanced Installer build task in Azure DevOps fails with output folder specified
Could you please make sure the related folder path does exist and is valid?
Maybe you can try to use it into a predefined build task like "Download pipeline artifact" or "Copy files"?
Marco28
I am 100% sure that the path is correct. This was working before, but started failing after the update of the task to 2.04.
I saw in GitHub that the change is related to the Output Path. It changes the type of the field from filepath to string and so it will take the literal value of the field instead of translating it to a path.
This means that relative paths can no longer be used.
I have further debated this with my dev team and, indeed it seems that starting with our last version (2.0.4) of Advanced Installer build task there are no longer supported relative paths in the "Output Package Folder" field. So therefore you will have to make sure you specify a full path in this field.
We apologize if this caused any inconveniences for you. Thank you for your understanding.
Just an update on this.
We have just released a new version of Advanced Installer Build task (v2.0.5) and starting with this version relative paths are supported again in the "Output Package Folder" field. So rebuilding this task with your original configuration should work again.
Hope this helped.
