a.guelle
[solved] Signing Tool Custom path is modified based on the running user
Hi AI-Team,
seems as if your users are the QA for new versions again...
The custom path for the signing tool in 17.4.1 is not static. It changes depending on the logged on user...
Attached you can see two pictures.
On my development machine I set the path to:
C:\Bamboo\CodeSigning\signtool.exe
As soon this is transfered to the build agent, it chenges to:
C:\Bamboo\Bamboo\CodeSigning\signtool.exe
So somehow the running Windows user is added to the path.
Angelo
Re: Signing Tool Custom path is modified based on the running user
Hello Angelo,
First of all, please accept my apologies for the encountered inconvenience.
Our QA team tests every new feature thoroughly, but unfortunately not even they can cover all the possible cases.
I have tried reproducing this issue, but I was not able to do so. Here are the steps that I took:
- create, on a virtual machine, a new project. In this project, point to:
C:\Test\CodeSigning\signtool.exe
- saved the project
- copied the project from the VM to my machine
- opened the project and checked the "Digital Signature" page. The project still pointed to the same path as I gave on the VM.
I have made sure that the two users (the one from my VM and the one from my main machine) are different.
Am I missing a step here? If so, could you please let me know what else I should do in order to reproduce this?
Hello Angelo,
I have done some further investigations and it looks like the path is indeed relative to the project.
Could you please proceed as it follows:
- open the .AIP file in a text editor (e.g. Notepad++)
- find the following component:
<COMPONENT cid="caphyon.advinst.msicomp.DigCertStoreComponent">
    <ROW TimeStampUrl="http://timestamp.digicert.com" SignerDescription="[|ProductName]" SignOptions="7" SignTool="0" UseSha256="1" CustomToolPath="..\..\..\Test\CodeSigning\signtool.exe" CustomToolCmdLine="sign /a /d &quot;&lt;signature description&gt;&quot; /du &quot;Description URL&quot; /fd SHA256 /tr &quot;http://timestamp.digicert.com&quot; /td sha256 "/>
  </COMPONENT>
and change the:
to:
CustomToolPath="C:\Test\CodeSigning\signtool.exe"
and let me know if that helps?
This way, the path should be static and you should no longer encounter this behavior.
Additionally, could you please let me know if that folder you are using is shared between the two machines (the dev machine and the build machine)?
a.guelle
this works as explained.
Thank you very much.
Angelo
Re: [solved] Signing Tool Custom path is modified based on the running user
Hello Angelo,
I am glad everything works as expected now!
