myid4truecallerweb
Running a Custom Action EXE file issue
Hi All,
I am new to Advanced Installer and what I need to do is to run a custom action (exe) file from APPDIR folder and get the file deleted once the installation is done.
Below is what I tried
1. Added the exe (Del.exe) as a temporary file.
2. Moved the file from Temp Folder to APPDIR
3. Created a a custom action (Del_Chck)
@ File Path : [&Del.exe]
@ Working Dir: APPDIR
@ Execution as deferred.
But I get the error message as shown in the attached image file.
Attached the api which I am trying to build.
Note: I tried a sample api from advance installer FAQ which run notepad.exe temporarily. I hope to my knowledge I followed the same steps, but still I get the error message during the installation. Also I just need to run this exe only by a Condition!!! in original API I added a dialog which has a checkbox(CheckBox_1), if that check box is checked then only this Del exe should run else should be excluded how ever finally get it deleted.
Kindly help me to re-solve and learn about this issue. Advance Thanks.
ExeWithWorkingDirectoryExample.zip
API zip file
(48.11 KiB) Downloaded 257 times
Issue JPG file
Issue JPG file
myid4truecallerweb
Re: Running a Custom Action EXE file issue
Hi All,
Selected "Launch file" in custom action instead of "Launch EXE from working directory", after the change the temp exe is running without any issue.
Thank
Thank you for your followup on this and for sharing your solution with us.
I am glad everything works as expected now.
