BaseHead
Jenkins AI Plugin Instance Missing
Hey!
I finally started to integrate AI into my Jenkins Build Server.
I have the plugin installed but I can only select 17.2 in the drop down for the "Instance" but I have 17.4 installed on the build server and my AIP project is for 17.4 also.
When I build I get an error that the project is too new etc...
Any Ideas how to resolve this and keep the project as 17.4?
thx in advance!
Steve
Re: Jenkins AI Plugin Instance Missing
Hello Steve,
Most likely, that is the Advanced Installer Instance you have created within your Jenkins Build Server.
In order to create/modify an instance, please proceed as it follows:
- open Jenkins in your browser
- "Manage Jenkins"
- "Global Tool Configuration"
- "Advanced Installer"
As you can see in the attached screenshot, whatever you input in the "Name" field will appear in the dropdown control.
With that being said, please either add a new instance of Advanced Installer or modify the current one accordingly.
BaseHead
thx Catalin!
that was the reason Yay!
I have another codesigning issue but I will create a new thread for that 8)
s.
You are always welcome!
I am glad it works as expected now. :D
