jwebber
FolderDlg Not matching Designer
Version 16.6.1
For some reason the FolderDlg looks different in installer running vs the designer (see attached). I turned the tracking disk space off. Also the labels I have on there are not showing and the header looks different. Any ideas on what could be causing this?
Jason
Re: FolderDlg Not matching Designer
Hello Jason,
Most likely, that theme requires the "Enhanced User Interface" to be enabled in order to be rendered.
Could you please go to "Themes" page --> "Settings" tab and see if the option is enabled? If not, could you please enable it and then re-build & re-test the package?
jwebber
I changed it from "Only on install" to "Always (install, uninstall and maintenance)" Still doesn't show what I am seeing in the designer. My labels don't show, and the disk space is still showing.
Hello Jason,
In order for me to have a better look over this, could you please forward me a copy of your .AIP file and a download link for the setup by e-mail at support at advancedinstaller dot com?
