janisito
Selected features not installed during upgrade
I have the following issue:
My installer has two features: Feature A and Feature B. Each feature installs a folder with a text file in it. When the user install version 1.0 he selects to install Feature B only, and hence only the folder named Feature B is installed.
Later when the application is upgraded to version 2.0 the user selects to install both Feature A and Feature B, however only Feature B is installed on the file system, which is very strange and not what I expected.
It seems the upgrade only installs the feature that was installed when installing version 1.0. How can I make the installer install select features during upgrade?
Installer
Installer
I have made a small sample project to illusatrate my problem. See attached.
Please advise.
Regards
Jan
App.zip
Advanced Installer Sample Project
(8.41 KiB) Downloaded 255 times
Re: Selected features not installed during upgrade
Hello Jan,
Most likely, this is happening due to the "MigrateFeatureState" action, whose purpose is to take the state of the features from the old package and transfer that to the new package.
In order to avoid this, please proceed as it follows:
In the newer version of your project:
- go to "Upgrades" page
- check the "Customize Advanced Installe upgrade rules" option
- from under "Upgrades", please double click on the upgrade that has the OLDPRODUCTS property assigned to it
- "Upgrade Action" tab --> uncheck the "Enable Migrate Features action" option
This way, the featureA should not be installed as expected and the folder should be created.
