Olaf S
Software versions...
Hej guys,
maybe I am a little confused, but...
since when is version "19.10064.1" more recent than "20.10042.0"? I cannot install my major MSI update because the package (20.10042.0) claims that a newer version is already installed. I have Adv. Installer 17.3 installed...
what is my faulty thought here? :-)
Olaf S
Re: Software versions...
honestly.... I was not kidding...
Olaf S
Re: Package Software versions...
Today I did some further testing:
1) using version 21.10042.0 to update package 19.10064.1 --> Did not work (a newer package of "package name" is already installed
2) using version 20.20042.0 to update package 19.10064.1 --> Did work.
Question: Why is the first section ignored? My understanding is that MSI supports and counts 3 segments of 5digits each. Right?
Is this a bug in Advanced Installer?
best regards
Olaf
Hello Olaf,
What I have noticed is that your versioning is quite wrong. If we have a look over the ProductVersion property article from Microsoft, we can notice that the ProductVersion has 3 main fields:
- major
- minor
- build
Each of the above has a maximum value, as it follows:
major --> 255
minor --> 255
build --> 65,535
Your minor version looks quite off, being 10064.
To be fully honest with you, I am not quite sure what is happening behind the scenes when using a bigger minor version, thus I can not really say why this is happening.
Hope this helps somehow!
