m4a.c4
.CAB Not Found
Hi there,
We are using Advanced Installer to install an Excel Add-in. The Installer is generated as part of our Azure Devops pipelines.
During installation, we have seen that occasionally our users have experienced an issue where the .cab source file is not found. This is not something that happens every time.
Is this something that is wrong with our AIP file?, something that we have not setup correctly or possibly a known issue/bug?
I have sent my AIP file and the installation log through to support at advanced installer dot com.
Connor
Re: .CAB Not Found
Hello Connor,
By having a look over the .AIP file, everything looks fine.
Could you please try the solution I presented in the "Source file not found" thread and let me know if that helps?
m4a.c4
Re: .CAB Not Found
Just to confirm, do we add this manually to the "Properties" window in the "Install Parameters" page?
Connor
Re: .CAB Not Found
Hello Connor,
Yes, the property should be manually added in the "Install Parameters" page.
