vshmelev
Web-to-app links handling
I would like to use Web-to-app links handling for by win32 app. But I have an error during MSIX package building:
Checking builds status
Build required.
[ Build_MSIX_APPX ]
Detecting Signtool compatibility
Detecting MSIX/APPX incompatible resources
Creating resources.pri file(s)
Building MSIX package:
D:\AdvancedInstaller\Your Application-Files\Your Application\ConsoleApp-Build_MSIX_APPX-SetupFiles\ConsoleApp-x64.msix
Preparing files
Preparing data for MSIX package
Creating AppxManifest.xml file
Validating AppxManifest.xml file
Validation failed on D:\AdvancedInstaller\Your Application-Files\Your Application\ConsoleApp-Build_MSIX_APPX-SetupFiles\AppxManifest.xml
Reason: '*.testConsoleApp.com' violates pattern constraint of '([0-9a-zA-Z]+(-[0-9a-zA-Z]+)*\.)+[a-zA-Z]{1,63}'.
The attribute 'Name' with value '*.testConsoleApp.com' failed to parse.
Source: <uap3:Host Name="*.testConsoleApp.com"></u
Line: 28
AppxManifest.xml failed to validate.
Error details
The changes that seems cause this error are adding appUriHandler extension with "*" in the begining
        <uap3:Extension Category="windows.appUriHandler">
          <uap3:AppUriHandler>
            <uap5:Host Name="testConsoleApp.com" />
            <uap5:Host Name="*.testConsoleApp.com" />
          </uap3:AppUriHandler>
        </uap3:Extension>
How can I set right namespace for those elements via Manifest Editor?
Image is attached.
Manifest Editor: add host element
Re: Web-to-app links handling
Please accept my apologies for the delayed reply.
This is currently under our investigations.
Please give me some more time to consult with your development team and I will come back to you as soon as I will have a conclusive answer.
I have discussed this with our development team and it looks like we do not have this declaration (uap5) in Advanced Installer.
I have added this improvement on our TODO list and this will be available in a future version of Advanced Installer.
Until then, it would greatly help us if you could share a copy of your .AIP file with us, by e-mail at support at advancedinstaller dot com so we can further investigate its' settings.
This improvement has been added in Advanced Installer 17.7, released on November 25th, 2020.
