gvnsandeep
Change of Control Size is not getting reflected in RunTime.
Hi ,
I am facing an issue with Control Sizing after updating the size of a dialog window. Could some one help me what is going wrong.
I have a requirement where in the size of one Dialog window to be increased, and based on the window, I have readjusted the controls height. However the control height is not getting reflected at run time. Please find the attached screen shots for reference.
Sandeep
Run Time.png (327.86 KiB) Viewed 1674 times
III Design Time.png (478.92 KiB) Viewed 1674 times
II Design Time.png (491.63 KiB) Viewed 1674 times
Re: Change of Control Size is not getting reflected in RunTime.
Hello Sandeep,
I have tested this and I was indeed able to replicate the behavior.
Unfortunately, I can not really say why this is happening nor was I able to find a workaround for this.
I have forwarded this to our development team and hopefully this will be fixed in a future version of Advanced Installer.
I will update this thread as soon as this issue will be fixed.
