fjsen
Error with ExitDialog
When you have a sprint theme selected and you activate "Launch application at the end of installation" you'll have a duplicated version of the button (with new look and another one with older look) as you can see in the attached picture:
How can I fix it? Is there any workaround or fix I can apply?
Kind regards,
Jose
Re: Error with ExitDialog
Hi Jose,
We apologize for the delayed reply on this.
We tested the scenario and replicated the issue. This seems to be an Advanced Installer issue indeed, thank you for bringing this to our attention. We will try to add a fix in the future and when so we will update you on this thread.
Until then, as a workaround, you should just go to "Dialogs" page, select "ExitDialog" and here select the [Run Your Application] button control. In the right pane just set the "Visible" attribute to "False". Rebuild the project and test this again.
Hello Jose,
This has been fixed in version 18.6 of Advanced Installer, released on August 25th, 2021.
