jstuardo
How to add parameter to Data in Registry Value Editor
If I add new value in the registry editor, the Edit Registry Entry dialog appears.
If I don't enter the name, and add a data, for example, [#MyFile.exe], a (default) entry is created with the data of "[#MyFile.exe]", including the quotes.
How can I add, for example, "[#MyFile.exe]" "%1" to the (default) key?
That kind of values are present, for example, when Zoom application is registered in the system, so that it can be launched using the web browser. In case of Zoom, this is the (default) entry of key HKEY_CLASSES_ROOT\zoommtg\shell\open\command:
"C:\Users\jaime\AppData\Roaming\Zoom\bin\Zoom.exe" "--url=%1"
I need to achieve the same using Advanced Installer.
Jaime
Re: How to add parameter to Data in Registry Value Editor
Hello Jaime,
If I understand correctly your request, what you want to do is to associate your application with an extension?
For instance, similar to how all the .txt files are opened using the default Windows' Notepad.exe:
Please note that this can be achieved by using our predefined support for "File Associations" - you do not need to manually edit a registry entry.
Please let me know if this is of help for you, otherwise please give me some more details about what you want to achieve.
jstuardo
No... the problem has nothing to do with that. Sorry if I was not very clear.
I will explain you with an example.
Please see this picture:
I have not found a way to add that parameter to the (default) node of the registry key. Note that the executable file is a property, for example, "[#MiFile.exe]" so it is not that trivial by just hardcoding the path together with the parameter.
By the way, I am creating a new protocol handler, such as Zoom does with zoommtg://. This is NOT an extension association.
Jaime
Hello Jaime,
I apologize for my last response, it looks like I have misunderstood your question.
In this case, I believe you should simply add the required parameter after adding the path to your executable file, e.g.:
Have you tried the above and it is not working as expected?
