Hello Akshay,
Yes, it is possible to achieve that.
We will need to share the custom action between the two stages. To do so, please proceed as it follows:
- go to
"Custom Actions" page
- select your custom action
- press the
"Sequence Share" button from the toolbar
- select the sequence where you want to share the custom action (in this case, it would be
"Install Execution Stage")
- after doing so, please select the shared custom action from under
"Install Execute Sequence"
- under
"Execution Stage Condition" please click on the
"Advanced execution scenarios..." hyperlink button. From the menu, please select the
"Skip action in Install Execution Stage if executed in Dialogs Stage".
This way, the custom action should only be executed during a silent install. During a full UI install, the action will be skipped in the
"Install Execution Stage" since it was executed in the
"Wizard Dialogs Stage".
- ca.png (322 KiB) Viewed 15071 times
