dharanidhar23
Install-WindowsFeature powershell command is not working
Hi Team,
I have a PowerShell custom action in the installer through which I am trying to install windows feature through "Install-WindowsFeature" command on windows server 2019. But the command is not recognizing in the installer and failing to execute the command whereas the same command is working fine when I try to run it from direct PowerShell command line on the same windows server machine.
Please check and assist !!!
Dharanidhar
Re: Install-WindowsFeature powershell command is not working
Hello Dharanidhar,
Please make sure that you are not launching the x86 PowerShell prompt within your setup, since ServerManager commands are supported only in the x64 version of PowerShell.
