Helios_47
Different behavier with ini-Files
Hello. Thats my first question here for Advanced Installer.
I'm using Advanced Installer 14.5.2 and I having a project with a full installer (server/client) and a client-installer. The server is a java wildfly application and the client program is a java application too.
When i install the full installer (server/client) then the ini-file for the client is correct and the client is starting after installation.
When i install only the client, then the ini-file is corrupt. Many lines are missing, for example the main-class. When i control the ini-file after their generation by the Java-Product section, the content is ok.
Why the ini-file has different content after installation?
Can somebody help me?
Best regards
Helios_47
Re: Different behavier with ini-Files
Hello Helios_47 and welcome to our forums,
Unfortunately, I can not say for sure why this happens.
Is the .INI file a standalone file (that you add to your package)?
If so, I do not see why it would be modified after the installation.
In order for me to further investigate this, could you please forward me the following resources:
- a copy of your .AIP file
- a download link for the setup
- some more details about your scenario (e.g. what is the INI file that gets corrupted)
by e-mail at support at advancedinstaller dot com?
Additionally, could you please give me some more details about this:
as I am not quite sure I understand what you mean.
