ChrisGue
"Use original installation path when upgrading": possible to have a dependency here
AI 14.1.1 b 79451 Enterprise
Updates: "Use original installation path when upgrading"
This option is checked.
However, my previous installation had a problem and as target folder '-' was set, instead of e.g. 'MyProduct'
So, in that case, I would like to have to reset to the standard installation path.
Is this possible?
Chris
Re: "Use original installation path when upgrading": possible to have a dependency here
Hello Chris,
Yes, it is possible to achieve what you need.
To do so, we can make use of:
- a "Set property" custom action that will set the APPDIR property, added as an "Init Event" on the "FolderDlg" dialog
- the "><" operator
Basically, the logic is as it follows. If APPDIR contains the "-" character, set the APPDIR to its' default value which I've taken from the "Install Parameters" page.
You are always welcome, Chris!
