nwillig
AI_DETECTED_DOTNET_VERSION value is wrong
I'm having issues with a custom action. That custom action simply prompt the user if the .net version detected is not equal or superior to the .net version my software needs.
I'm aware that I can use launch conditions to re-create that behavior but i'd rather leave the user the option to dismiss the message and go on with the installation because he might not be using the subset of my solution that actually requires the said .net version.
In any case, here is what my lauch condition look like :
and here is the result on a target machine :
As you can see, AI_DETECTED_DOTNET_VERSION value is 4.6.2 here but the command line tool (available here : https://github.com/jmalarcon/DotNetVersions) shows me i have a 4.8 version of .net installed thus making my custom action trigger unnecessarily.
Re: AI_DETECTED_DOTNET_VERSION value is wrong
The way we receive the .NET Framework version is from the registry. Here is the key that we are looking for:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full\Release
Could you please open registry editor, navigate to that key, take a screenshot and forward it to me?
nwillig
Here it is.
Thank you for the provided screenshot.
However, please note that I have asked about the "Full" key, not the "Client" key.
Could you please select that, take a screenshot and post it here?
nwillig
Sorry about the misunderstanding.
Here it is.
Thank you very much for the screenshot.
It looks like the 4.8 version of .NET Framework is indeed installed.
If possible, could you please check the same key, but from the WOW6432Node?
I am thinking that maybe your setup is of 32-bit ("Install Parameters" page --> "Package Type") and the search is being redirected to the WOW6432Node. Please post of a screenshot of that as well.
Additionally, could you please create an installation log using the AI_DEBUGLOG=1 parameter and forward that to me so I can further investigate this? The command line would look like this:
msiexec /i <path_to_msi> AI_DEBUGLOG=1 /L*V <path_to_log>
if your setup is an MSI and:
setup.exe AI_DEBUGLOG=1 /L*V <path_to_log>
if the setup is an EXE.
nwillig
thank you for your answers.
here is the syswow screenshot
and here is a proof that our installer is indeed configured as a 32bit one
I also have the log file you asked for but i'm not comfortable sharing that on a public forum. any email I could send that to?
Thank you for the provided screenshot. Based on it, it looks like the correct version should be detected.
Sure thing, please forward me the log file by e-mail at support at advancedinstaller dot com.
nwillig
email sent
nwillig
Did you get my email?
Please accept my apologies for the delayed reply (we had few days off - National Holidays).
I've had a look over the e-mail and it looks like the e-mail is not received.
Could you please try to resend it?
nwillig
I've just re-sent it.
I have answered you over the e-mail.
nwillig
I've sent you the AIP as well, do you have any updates?
I have replied to your e-mail.
