TheRocket
Command line - Change pre-requisite min version / max version
Thu Nov 19, 2020 8:46 pm
You are working with advanced installer 17.6 to mass change the versions of your products.
Your product A have a prerequisite of your own product B.
Via command line, you want to Change the Min and Max version of the prerequisite display. Ex:
/edit projecta.aip /UpdatePrerequisite "Product B" ......
From documentation, it seems we can only change the min and max version values for the searches, not for the "Properties - Display" section.
I would suggest to expose the Min and max values from the "Properties - Display" section of a prerequisite.
Thanks!
Re: Command line - Change pre-requisite min version / max version
Fri Nov 20, 2020 1:45 pm
I've done some digging and it seems that you are indeed right, we do not have CLI support to manipulate those two fields - Minimum and Maximum version fields from the "Display" section.
I will add this on our TODO list of improvements and hopefully this will be available in a future version of Advanced Installer.
Thu Mar 25, 2021 5:02 pm
This improvement has been added in version 18.1 of Advanced Installer, released on March 23rd, 2021.
Return to “Feature Requests”
