After restarting visual studio I get the following error:
The 'AdvInstVSIntegrationPackage' package did not load correctly...
The ActivityLog.xml file referenced in the error message contains the following information:
<entry>
<record>573</record>
<time>2020/11/23 18:56:59.428</time>
<type>Information</type>
<source>VisualStudio</source>
<description>Begin package load [AdvInstVSIntegrationPackage]</description>
<guid>{634D2762-4905-4843-B74C-649D410524F9}</guid>
</entry>
<entry>
<record>574</record>
<time>2020/11/23 18:56:59.444</time>
<type>Error</type>
<description>SetSite failed for package [AdvInstVSIntegrationPackage]Source: 'AdvInstExtensionVSIntegration.vcs16' Description: Could not load file or assembly 'Microsoft.VisualStudio.Threading, Version=16.7.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified.
System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualStudio.Threading, Version=16.7.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified.
File name: 'Microsoft.VisualStudio.Threading, Version=16.7.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'
 at Caphyon.AdvInstVSIntegration.AdvInstVSIntegrationPackage.InitializeAsync(CancellationToken cancellationToken, IProgress`1 progress)
 at Microsoft.VisualStudio.Shell.AsyncPackage.<>c__DisplayClass20_0.<<Microsoft-VisualStudio-Shell-Interop-IAsyncLoadablePackageInitialize-Initialize>b__1>d.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
 at Microsoft.VisualStudio.Threading.JoinableTask.<JoinAsync>d__68.MoveNext()
 at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
 at Microsoft.VisualStudio.Services.VsTask.RethrowException(AggregateException e)
 at Microsoft.VisualStudio.Services.VsTask.InternalGetResult(Boolean ignoreUIThreadCheck)
 at Microsoft.VisualStudio.Services.VsTask.GetResult()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
</description>
<hr>80070002</hr>
<errorinfo></errorinfo>
</entry>
<entry>
<record>575</record>
<time>2020/11/23 18:56:59.457</time>
<type>Error</type>
<description>End package load [AdvInstVSIntegrationPackage]</description>
<hr>80070002</hr>
</entry>
