gvnsandeep
How to build the AIP Project from a C# Project
We are in the process of automating the builds of Advanced Installer Projects. Could you please help on "How can I achieve the same from a C# Project"?
I have tried invoking the command line arguments from a C# Project. However it didn't worked, I am not sure where I am going wrong. I am attaching a project, could you please go through that and let me know where I am going wrong?
Here is the code which I am using in C#
Process p = new Process();
ProcessStartInfo startInfo = new ProcessStartInfo();
startInfo.WorkingDirectory = @"C:\Program Files (x86)\Caphyon\Advanced Installer 17.7\bin\x86\";
startInfo.FileName = @"C:\Program Files (x86)\Caphyon\Advanced Installer 17.7\bin\x86\AdvancedInstaller.com";
startInfo.Arguments = @"AdvancedInstaller.com /edit ""\C:\Users\sandeep\Documents\Advanced Installer\Projects\Test.aip\"" / SetVersion 3.1.201";
startInfo.RedirectStandardOutput = true;
startInfo.UseShellExecute = false;
startInfo.CreateNoWindow = true;
p.StartInfo = startInfo;
p.Start();
string result = p.StandardOutput.ReadToEnd();
MessageBox.Show(result.ToString());
Sandeep.
Command Prompt POC.zip
(36.7 KiB) Downloaded 224 times
Re: How to build the AIP Project from a C# Project
Hello Sandeep,
The problem seemed to be caused by multiple typos in the passed arguments.
First of all, please note that you are already providing the path to the AdvancedInstaller.com tool here:
Therefore:
should look like this:
startInfo.Arguments = @"/edit ""\C:\Users\sandeep\Documents\Advanced Installer\Projects\Test.aip\"" / SetVersion 3.1.201";
Secondly, please note that you have an extra backslash character ("\") here:
The above should look like:
""C:\Users\sandeep\Documents\Advanced Installer\Projects\Test.aip\""
The one before the C:\ drive.
Lastly, you have an extra space here:
The above should look like this:
/SetVersion 3.1.201
The final command line should look like this:
startInfo.Arguments = @"/edit ""C:\Users\sandeep\Documents\Advanced Installer\Projects\Test.aip\"" /SetVersion 3.1.201";
