GabrielIacob
Azure DevOps - License removal at Post-job
I observed that, if the Azure DevOps "Use Advanced Installer" is used, the post-job task will remove the license file.
This becomes an issue for the following scenario:
Timeline:
Pipeline 1 starts build on agent X
Pipeline 1 hits "Use Advanced Installer" task and installs AI
Pipeline 1 hits a Batch task that calls AI to build the installers.
Pipeline 2 starts build on same agent.
Pipeline 2 hits "Use Advanced Installer" task
Pipeline 1 hits post-job task and removes license.
Pipeline 2 hits same Batch task but fails because license was removed from that machine.
What should be a proper approach for such scenario in order to have successful builds on both pipelines, taking in consideration that preventing hitting the same machine is not an option.
Would changing the Batch to the "Build Advanced Installer" task solve this issue?
Gabriel Iacob
Re: Azure DevOps - License removal at Post-job
Hi Gabriel,
Indeed this is our current default design. The License file is deleted on post-job task.
As a workaround, yes please use a "Advanced Installer Build" task (instead of a batch to call Advanced Installer) and specify your license key in the "Advanced Installer Build" task.
Let us know if this helped.
Hi Gabriel,
I have talked with our dev team about this limitation and we will try to add an improvement in this regard. We will try to make available a pipeline variable you could define in Azure DevOps and when such variable is set the license file cleanup on post-job task to be skipped.
When such improvement will be available we will update this forum thread.
Hi Gabriel,
Also, as another possible workaround solution just add a "PowerShell Script" task (just after "Build Advanced Installer" task) with the following code:
Write-Host "##vso[task.setvariable variable=advinst.cleanup;]"
Check attached screenshot.
This should help you get rid off the license cleanup on post-job task.
GabrielIacob
Using the azure task for building did the job.
Thank you,
Gabriel Iacob
You are always welcome, Gabriel!
We are glad you got this working.
Our dev team released a fix for this issue. From now on, when you have concurrent pipelines building an Advanced Installer setup project you can skip the license cleanup on post-build task.
To do so you should just define a pipeline variable like this:
  • Name: advancedinstaller.cleanup
    Value: false
Check the attached screenshot.
