markusen
Azure DevOps with aic File
I want to execute an aic File in Azure DevOps
- I tried the following
  - task: AdvancedInstaller@2
    inputs:
      advinstVersion: '17.7'
      advinstLicense: 'd7e67e43a342ae38c0cf487108307425'
      aipPath: 'Setup/es_Setup.aip'
      aipBuild: 'DefaultBuild'
      aipPackageName: 'es5Insider$(buildBuildId).msi'
      aipOutputFolder: '$(Build.ArtifactStagingDirectory)\MSI'
      aipExtraCommands: 'Setup/aic/testproject.aic'
I get the error:
Unknown command in edit mode: Setup/aic/testproject.aic.
Do I need to put an command before the path to the aic File?
Or what am I doing wrong?
Re: Azure DevOps with aic File
A file of commands (.aic file) is executed as it follows:
AdvancedInstaller.com /execute <path_to_project_file> <command_file_path>
For more information about this, please have a look over the "Working with Advanced Installer from the command line" article.
markusen
Thank you for your response. I know how to execute this from the Command Line.
But I want to use the Azure DevOps Task as stated in the question.
How do I integrate the .aic File in the Azure Dev Ops Task?
To achieve what you want you should simply copy the content of your .aic file (excluding its first line: ;aic) and add the commands in the "Command Line Arguments" section of your DevOps build task. For instance:
SetVersion 1.2
SetProperty TESTPROP="TestValue"
Save
Hope this helped.
markusen
Thank you Daniel. That information was very helpful.
You are always welcome!
