Most likely, this is happening due to your prerequisite's condition(s).
Please note that a prerequisite's condition is evaluated twice:
- before the prerequisite is installed
At this point, the condition should be
false => prerequisite will be installed
- after the prerequisite is installed
true => the prerequisite was correctly installed
Did you add the prerequisite to your project from our predefined list of prerequisites?
If so, after the reboot, could you please check the registry entry specified in
"Prerequisites" page --> your prerequisite -->
"Install Conditions" tab and see if it has the correct value?
- InstallCondition.png (119.99 KiB) Viewed 2426 times
Additionally, if you are installing on a 64-bit machine and your setup is of 32-bit type (
"Install Parameters" page -->
"Package Type"), please make sure the
"Use 64-bit locations when evaluating condition on 64-bit machine" is checked, as in the above screenshot.
Now, in what regards the reboot, did you check the
"Reboot system after installing this prerequisite" option from
"Properties" tab? I am asking because I have just tested this and the VC++ Redistributable setup did not ask for a reboot on my test machine.
