blackpanda
System Requirement Settings: Memory checking is incorrect
I got a problem when I set the minimum Physical Memory, at System Requirement Page, for my installer was 3584 MB (3.5 GB)
Then I set My VM was 3.5 GB memory, but the installer complained as the following photo
Then I had to change my aip to set 3583 MB and it works fine.
Is that a bug?
Re: System Requirement Settings: Memory checking is incorrect
If the VM has 3584 MB of memory, then the fact that the Launch Condition is triggered is correct.
You can, for instance, check the memory on your VM as it follows:
- open PowerShell
- run the following command:
(systeminfo | Select-String 'Total Physical Memory:').ToString().Split(':')[1].Trim()
