prerak6962
Conditional Credentials for Service User
Fri Dec 11, 2020 5:57 pm
I have a very unique requirement for one of our projects.
In the installer, the user can select the type of database he wants to install. The possible options are:
1. SQLite3
2. MS SQL
The project also contains a service. What we want is if the user selects SQLite3 in one of the dialogs, the service should be installed to run under LocalSystem account. But if the user selects MS SQL, he'll provide the credentials for it (username and password) and the same credentials should be used to run the service now.
So, is there a way I can conditionally set how to run the service (LocalSystem account or user account) based on the user input?
Thank you.
Prerak
Re: Conditional Credentials for Service User
Thu Dec 17, 2020 5:00 pm
Hello Prerak,
Unfortunately, I'm afraid we do not have predefined support for that.
I'd say that the best approach would be having two custom actions:
- one that creates & starts the service under a normal user
- one that creates & starts the service under the LocalSystem account
Both custom actions should be scheduled after the "Add resources" action group, with their execution time being set to "When the system is being modified (deferred)".
