NovaES
Code signing problem
I have formatted my computer by installing an NVMe. I have reinstalled my certificate but it is not recognized by AdvancedInstaller.
The installation is successful for me and when I go to the certificate store it appears installed, but Advancedinstaller cannot find it.
Re: Code signing problem
This might happen if your certificate has an availability > 5 years.
We have recently added this improvement to reduce the "noise" certificates (basically to make the list more compact).
In order to check the valability of a certificate you can open "certmgr.msc" --> the certificate store where your certificate is installed --> right click on your certificate --> "Open" --> "General" tab --> "Valid from" field.
If that is not the case: if the certificate was installed on the "Local Machine", could you please try to launch Advanced Installer with administrator privileges and let me know if that helps?
NovaES
Re: Problema de firma de código
Hola, me he dado cuenta que al poner un nuevo disco duro e instalar el sistema operativo desde 0 la firma digital no sirve, por medidas de seguridad. He vuelto a mandar una solicitud de re-emisión para obtener el PFX y seguir firmando digitalmente.
Gracias
I am glad you were able to find the culprit.
