Balaji
how to add help feature in bootstrapper aip project
I have created an aip project to produce bootstrapper executable.
I want to add help feature in this bootstrapper executable (created using advanced installer).
How to achieve this?
Balaji
Re: how to add help feature in bootstrapper aip project
Hello Balaji,
I am not quite sure I understand what you want to achieve.
In order for me to further assist, could you please give me some more details?
Balaji
As we all know, for installer executables(tried for other than AI) there is a feature of getting help.
Help in terms, what commands we can fire on this installer executable.
e.g. sample.exe has no ui command, uninstallation command, install/uninstall command etc.
I need this type of list. That contains what operations we can do using this executables.(using command line).
Balaji
Hello Balaji,
In order to get the list of commands availalbe for the setup.exe, all you need to do is:
- open a command prompt
- run the setup, as it follows:
setup.exe /?
or
setup.exe /help
