NovaES
Create a condition for installer
I have recently modified the configuration of my installer, when an installation is performed it no longer removes the files, but it installs it first (see attached screenshot).
Code implemented in program files:
(AI_CLEAN_RESOURCES_UNINSTALL = "1") AND (NOT UPGRADINGPRODUCTCODE)
My problem is that when the name of one of the shortcuts that is created on the desktop is modified, it is not modified.
I would like to know how to program and detect these modifications so that the installer with this new configuration modifies this as well as if something has been eliminated, it can be eliminated.
Re: Create a condition for installer
It is not quite clear to me what this condition is used for.
Have you created, in the shortcut location, a "File Removal" operation (to remove the shortcut) that has the above condition?
If possible, could you please forward me a sample project that reproduces this issue or a step-by-step test case which I can follow in order to reproduce this?
