Tatyana Mykhnevych
Update ONLY minimum prerequisite version via cmd
I build installer using cmd commands for AdvancedInstaller project.
I have Advanced Installer version 17.2.
Is there any way to update ONLY minimum feature-based prerequisite version via cmd?
Also when I use Update Prerequisite Option https://www.advancedinstaller.com/user- ... isite.html it creates new PreReqSearchComponent record in .aip file, not updates old one.
Tanya
Re: Update ONLY minimum prerequisite version via cmd
Hello Tanya,
I have run a few tests on our end and you are indeed right.
When using the /UpdatePrerequisite option, a new search will be added instead of the already existing one being updated.
I have added this improvement on our TODO list and hopefully this will be added in a future version of Advanced Installer.
Until then, I'm afraid the only workaround would be deleting the prerequisite (/DeletePrerequisite) and adding it once again with the configured version for your search (/NewPrerequisite).
Hello Tanya,
This has been fixed in version 18.1 of Advanced Installer, released on March 23rd, 2021.
