Gantori
Filenames containing Unicode are mangled when installed
The filename containing both English and Arabic appear fine in the project.
However, when installed under C:\Program Files (x86)\ the Arabic text part of the filename is mangled into boxes.
See snapshots below.
Building and Installing under Windows 7
Thank you.
PS.
Re: Filenames containing Unicode are mangled when installed
That is most likely happening due to the encoding used by your package.
Please go to "Builds" page --> "Configuration" tab --> expand "Database Encoding" and change to "UTF-8 encoding (support Unicode characters to be displayed)" option.
