cagatay
Can't Build from Electron App
A month or so ago I built the first version of my app with Advanced Installer and couldn't believe how easy it was. Well, today I had my first update ready but I cannot build it. I created a new project from scratch just to be safe and followed the Electron tutorial in case I missed anything. I keep getting the following error:
Failed to create resources.pri file.
Advanced Installer 17.8 build f367c492
*** Stack Trace (x86) ***
[0x76bea892]  RaiseException()
[0x0275157a]  -----
[0x017a3a9d]  -----
[0x0c026fc0]  -----
[0x00e40000]  MODULE_BASE_ADDRESS
What should I be looking into?
Thank you
Re: Can't Build from Electron App
Hi Çağatay and welcome to our forums,
Not so sure why this happens. Could you send by email at support at advancedinstaller dot com your .AIP (project file) and the full build log displayed by Advanced Installer? So we can fully test and investigate your scenario?
Return to “Feature Requests”
