objc
Registry key not being removed as directed
Sun Jan 10, 2021 5:54 am
I am trying to remove some registry keys upon install, such as this one:
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{B4BFCC3A-DB2C-424C-B029-7FE99A87C641}
It is not being removed. I have the "Remove this key with all of its ..." option checked in Properties for this key. Is there something else I need to do?
Note that this is a standard key that comes with a fresh Windows installation.
When I select the portion of the registry tree I want to remove and click Export Reg, below is the code that is generated. It's not removing the keys themselves like it should.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{088e3905-0323-4b02-9826-5d99428e115f}]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{B4BFCC3A-DB2C-424C-B029-7FE99A87C641}]
... etc
Re: Registry key not being removed as directed
Wed Jan 13, 2021 6:28 pm
If that is a standard registry key, I am assuming that you did proceed as it follows:
- manually create the registry key in "Registry" page
- set the "Remove this key with all of its values and subkeys" option from the "Operations" tab
If that is the case, please make sure that:
- the specified component is uninstalled (assuming that you delete this on a component uninstall)
- the condition is evaluated as true
In addition to the above, we also need to pay attention to registry redirection here.
For instance, if your setup is a 32-bit setup and the install/uninstall takes place on 64-bit machine, the setup will try to remove the registry located at:
HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{B4BFCC3A-DB2C-424C-B029-7FE99A87C641}
rather than the registry located at:
