objc
Remove watermark?
I am using the Air theme. I have scoured this forum, and every solution to removing the watermark no longer works. There is no static text element I can click on in the dialogs screen to remove the text.
I am using an Architect project in Advanced Installer version 17. What is the proper way to remove the watermark?
Re: Remove watermark?
I have done some tests on our end, but unfortunately I wasn't able to remove the watermark either.
I have forwaded this to our development team for further investigations.
I will update this thread as soon as I will have more information.
After further discussing this with our development team, it looks like the background image must be modified manually (e.g. removing the watermark).
After modifying the image, please go to "Themes" page --> "Images" tab --> replace the glassbackgroundsmall.png with the modified one.
The above image can be found in the following location:
C:\Program Files (x86)\Caphyon\Advanced Installer 17.8\themes\common-res\frame
For instance, if you are using the "Air --> Air" theme, the imagine is found in the following location:
C:\Program Files (x86)\Caphyon\Advanced Installer 17.8\themes\common-res\frame\powderblue\rtlo-glassbackgroundsmall.png
AquaComm
Here's a blank file to use..
Watermark removed.
Watermark removed.
Thank you very much for your followup on this!
I am sure this will be of help for further users facing a similar scenario.
