michaelthibeault
Button scaling bug
I am having issues when running the MSI created within different configurations.
Even though I tried all the 4 image scaling options (Advanced installer v17.2)
The buttons image show too big and pixelized.
Any idea ?
Big Icons.png (53.06 KiB) Viewed 13277 times
michaelthibeault
Re: Button scaling bug
Still no assistance an it.
Anyone with an idea ?
michaelthibeault
I Looked into this avenue:
viewtopic.php?f=2&t=29984&p=79545&hilit ... ico#p79545
If it is an issue with the .ico?
Why is this happening with advanced installer and not with install shield ?
Hello Michael and welcome to our forums,
You can try to lower the image's pixelization from "Dialogs" page --> your image --> under "Properties" (right side) --> "Icon Size".
By default, the images are 32x32, but you can choose to either have them as 16x16 or 48x48.
michaelthibeault
Catalin wrote: ↑Mon Feb 01, 2021 5:26 pm Hello Michael and welcome to our forums,
Thanks but the 16x16 is too small and the 48x48 is the size that I had in the screenshot that is too big.
Is it possible that different screen aspect ratio affect the .ico that is being used ?
This was not happening with install shield.
michaelthibeault
Either the screen aspect ratio or the DPI triggers something when the installer is running that makes it select the 48x48 icon instead of the 32x32.
The resolution is the same in both computers.
The same version of windows.
size is very similar, although the one with the issue as a 13 inch display as opposed to the one without the issue that has a 14 inch.
Zoom level is the same.
Unfortunately, I can not really say what the Windows Installer's logic is behind this.
Regarding your other post, I've done some research and it looks like there are tools that can help you achieve what you want.
Most of the tools I've seen help you merge multiple sizes images into an .ICO file, but I believe they can do the opposite as well.
In "Themes" page --> "Images" tab you can see the path to each .ICO file. For instance, if you are using the classic theme, the path will look something as it follows:
<AI_THEMES>classic\resources\completi.ico
which, on my machine, translates to:
C:\Program Files (x86)\Caphyon\Advanced Installer 17.9\themes\classic\resources\completi.ico
michaelthibeault
The same issue is not seen when we are using install shield in the same OS environments.
So I still believe it is something in advanced installer that sets something in the MSI.
I am investigating with 2 IT resources, and the only parameter that we have been able to identify is the difference on the screens that have the issue vs the ones that do not have the issues is the screen vertical dimension affecting the DPI.
Any Idea which parameters in Advanced installer that could be affecting this?
michaelthibeault
I tried using "FIxed icons in the theme menu"
Although this created a new problem
Bad Banner.png (49.51 KiB) Viewed 13210 times
michaelthibeault
Catalin wrote: ↑Fri Feb 05, 2021 4:34 pm Hello,
See the completi.ico
There is only one.
What should I do with it ?
In advanced installer, it seems that there are 3 formats, but in the path of gave me, I only see one.
michaelthibeault
Could I get some help on this ?
Please give me some more time as I am still discussing this with our development team.
So far, it looks like the image is selected based on the DPI.
In addition to this, we only support standard DPI (100%, 125%, 150%, 200%).
First of all, please disregard my above response.
After a bit more investigation, it looks like the .ICO file does not actually contain multiple images, but just one 32x32 image.
I have further discussed this with our development team, but unfortunately we do not have a resolution for now.
I have created a ticket so they can further investigate it.
I will update this thread as soon as there will be a resolution to this matter.
michaelthibeault
Thank you very much for taking the time :)
You are always welcome! :)
It is always my pleasure to try and help.
I am sorry we were not quite able figure this out.
Hopefully the development team will be able to improve this in the future.
