dertom234
Visual Studio Cnfigurations Window is empty
my first try with Advanced installer and first Problem after 2 Minutes :)
I am trying to import an Visual Studio Project. After selecting my Project.sln File i get an an empty window where my Debug und release configuration should show up. (see attchment).
I don`t even have a clue where to start searching for the error.
Can someone please give me an hint ?
Greetings
Tom
Re: Visual Studio Cnfigurations Window is empty
Hello Tom and welcome to our forums,
I am assuming the Visual Studio solution file is built on the machine where you are trying the import.
If that is the case, in order for me to further investigate this, can you please send us your VS solution (SLN file) and all of the project files it includes (only the project definition files without the source code files) by e-mail at support at advancedinstaller dot com?
In addition to that, is this issue reproducible with any solution file or is it particular to only one solution?
dertom234
Yes it`s the machine.
Done. Many thanks for you help.
Have to try this. On this machine is currently only those one Project. But will give it a try. It`s now evening here. Will try it on Monday.
Best regards
Tom
dertom234
Any updates on this ?
Hello Tom,
This is currently still under our investigation.
I will update this thread as soon as we will reach a conclusion.
dertom234
meanwhile my Test-Version has expired.
Good part is that i now know why you offer the Testversion..............
Hello Tom,
I am sorry to hear this.
Unfortunately, this is still under investigation on our side.
Please note that after we will have this figured out, we can extend your trial period with another 30-days so you can continue testing your setup.
Hello Tom,
I come with good news!
It looks like this was indeed an issue on our side. Our development team has already fixed this.
After a RC version will be built, I can forward you a download link so you can test the fix.
Could you please confirm that the correct address is the one you have used to create the account on our forum?
dertom234
Yes you can get me there :)
Thanks in Advanced
Hello Tom,
I have sent you the download link over the e-mail.
