ybe
Can I trigger a "CustomAction without sequence" from silent installer?
Hi
I'm running a silent installer of my application. When I run the installation through UI, I have an important "CustomAction without sequence" attatched to one of my dialogs. This CustomActon is never triggered when running the silent installer. Is there any way to trigger this custom action through the silent installer command (without adding it to sequence)?
Re: Can I trigger a "CustomAction without sequence" from silent installer?
Unfortunately, that is not possible, as during a silent installation, the whole UI stage (where the dialogs are spawned) is skipped.
The only way would be to add your custom action under the "Install Execution Stage" as well.
