ybe
Why does my Edit Box write every character into the log?
In my installer dialog, I have one Edit Box that for some reason prints every character to the install log. So if I simply enter "Hello" in that Edit Box it comes out as follows:
MSI (c) (FC:7C) [11:25:05:838]: PROPERTY CHANGE: Modifying HOSTNAME property. Its current value is 'H'. Its new value: 'He'.
MSI (c) (FC:7C) [11:25:05:965]: PROPERTY CHANGE: Modifying HOSTNAME property. Its current value is 'He'. Its new value: 'Hel'.
MSI (c) (FC:7C) [11:25:06:157]: PROPERTY CHANGE: Modifying HOSTNAME property. Its current value is 'Hel'. Its new value: 'Hell'.
MSI (c) (FC:7C) [11:25:06:339]: PROPERTY CHANGE: Modifying HOSTNAME property. Its current value is 'Hell'. Its new value: 'Hello'.
Why does it do this? I just want it to print Hello, not every change..
Re: Why does my Edit Box write every character into the log?
Please note that this is the normal behavior.
The value entered in the Edit Box control is stored in the form of an installer property.
At first, this will have an empty value, but with each character introduced in the Edit Box control, the value of the property is changed.
