Minnu123
Uninstall from control panel based on customer choice
I am requesting someone to give a solution for the below scenario
Our application:
scenario 1 : Upgrade by another version
In the application customer used to keep some user data during application run. So during upgrade these files are maintained[used the property Dont overwrite files in Upgrading product code] to not remove so that user data wont remove
scenario 2 : Control panel uninstall
when uninstall invokes from control panel, all application files are getting removed.. this includes user data too..
Scenario 1 & 2 is the expected scenario and its working fine
But in this scenario, there is a risk that customer can accidentally uninstall from control panel. In that case all user data too removed
Inorder to overcome this, we need to display a warning message to customer that uninstall will remove all data. Then an option should display from where customer can choose the uninstall type he wants
1. uninstall should remove the product completely[regular uninstall]
2. Uninstall should keep the files with the property Dont overwrite files in Upgrading product code.
Could some one please advice me to address this.
Thanks in advance
Re: Uninstall from control panel based on customer choice
In order to achieve what you want, you can proceed as it follows:
  • go to "Custom Actions" page and create a "MessageBox" custom action that has two buttons (Yes and No)
  • schedule it under "Install Execution Stage" --> between "Searches" and "Paths Resolution" action groups
  • under "Execution Stage Condition", uncheck "Install" and "Maintenance"
  • now condition the files you do not want to be removed as it follows:
REMOVE = "ALL" AND BTN_PRESSED = "IDNO"
This way, during an uninstall (REMOVE = "ALL"), if the user will press the "No" in the messagebox, the file will not be removed.
