Local IIS Website - automatic IP assignment to Hostname
Hello guys,
Recently, one of our users has encountered some difficulties regarding the IP assignment to a hostname for an IIS website.
To be more precise, here is the question:
Would it be possible to assign the IP address to the IP address of the machine that it's installing from? Thanks.
With that in mind, I have decided to create this How-To, hopefully it will be useful for other users facing a similar scenario as well.
Prerequisites:
  • Advanced Installer Enterprise project
  • IIS feature should be enabled on the target machine (in order to use the sample project I will provide at the end of the article)
Before we begin, it is important to note that, in case of a locally installed website, the "hosts" file must also be update accordingly with the IP to hostname bind.
The "hosts" file is used for Name to IP Address resolution.
The hosts file is one of several system facilities that assists in addressing network nodes in a computer network. It is a common part of an operating system's Internet Protocol (IP) implementation, and serves the function of translating human-friendly hostnames into numeric protocol addresses, called IP addresses, that identify and locate a host in an IP network.
In some operating systems, the contents of the hosts file is used preferentially to other name resolution methods, such as the Domain Name System (DNS), but many systems implement name service switches, e.g., nsswitch.conf for Linux and Unix, to provide customization. Unlike remote DNS resolvers, the hosts file is under the direct control of the local computer's administrator
With that in mind, we can break our request into two smaller requests:
  • get the IP Address from the machine running the setup
  • update the "hosts" file accordingly
1) Get the IP Address from the machine running the setup:
To achieve this, we can use a custom action. The custom action can either be a PowerShell script, a VBScript, a C# .DLL, etc. In today's article, we will use a PowerShell custom action.
Even in PowerShell, there are multiple ways of retrieving the IP Address of a machine. For this task, we will make use of the "Test-Connection" cmdlet.
If we open a PowerShell prompt and run the following command:
Test-Connection -ComputerName $env:ComputerName -Count 1
we will receive the following:
As you can see, the above cmdlet returns some nice information, including the "IPV4Address", which we are interested in. To get more details about this object, we can proceed as it follows:
(Test-Connection -ComputerName $env:ComputerName -Count 1).IPV4Adress
The above object has a property that we need, namely "IPAddressToString". We will need to store this property into a variable.
$ipv4Address = (Test-Connection -ComputerName $env:ComputerName -Count 1).IPV4Address.IPAddressToString
1.1) Implementation of the script in Advanced Installer:
Basically, what we need to do here is:
  • go to "Custom Actions" page and add a "PowerShell inline script" custom action
  • schedule it as in the following screenshot:
Here would be the content of the custom action:
# Get the IPV4 address and stores it in a variable, then create a property with the value.
# We will further use this property in the IP field ("IIS" page --> your website --> "Bindings/SSL")
AI_SetMsiProperty IP_ADDRESS $ipv4Address
As you can see, we further use the value of our $ipv4Address variable to set a property.
This property will further be used in the "IP" field of our binding in "IIS" page --> your website --> "Bindings/SSL"
This is pretty much it regarding the retrieval of the IPAddress from the machine where the setup is installed.
2) Get the path to the "hosts" file + Implementation in Advanced Installer
The default location of the "hosts" file, on the Windows OS, is:
SystemFolder\drivers\etc
which resolves on my machine to:
C:\Windows\System32\drivers\etc
Here, we will need another custom action that will construct the path for us, since there is not any predefined variable / property that holds the above path.
To achieve this, we can make use of the "Environment class" and its' "SystemDirectory" property.
The PowerShell script will look as it follows:
# Get the path to the "hosts" file which we will need to update with our IP + hostname bind
# This path will then be stored in a property, which we will use to create a Property Based folder.
# This folder will "hold" our "Text file update" operation
$system32 = [System.Environment]::SystemDirectory
$hostsDir = Join-Path -Path $system32 -ChildPath "\drivers\etc"
AI_SetMsiProperty HOSTSDIR $hostsDir
Now that we have constructed the path, we can move on to the next step which would be the creation of a property based folder (HOSTSDIR). This folder will hold the "Text file update" operation that will update the hosts file, adding the IP and the hostname to it. Here is how we can proceed:
  • go to "Install Parameters" page and create an empty property as it follows:
  • in "Files and Folders" page, right click on "Application Folder" --> "New folder" --> "Property" based --> select the HOSTSDIR property
select the earlier created folder and add a "Text file update" operation that will update the "hosts" file by "Appending/Creating" the following to the file:
[IP_ADDRESS]	www.demowebsite.com
Below, you can find attached a sample project which implements every step presented above:
Sample.zip
(32.63 KiB) Downloaded 2613 times
Hope this helps! :)
HienHo
Re: Local IIS Website - automatic IP assignment to Hostname
Excellent article Catalin! Very well written indeed.
One question: would the added entry in the hosts file automatically get deleted after an un-install? Thanks.
Hien
Hello Hien,
Thank you once again for your kind words!
Unfortunately, the added entry will not be removed upon uninstall.
If you want to remove the entry, we will need to have a cleanup custom action.
The custom action can look something as it follows:
$hostsFile = Join-Path -Path $hostsdir -ChildPath "\hosts"
$stringToBeRemoved = "$ipv4Address" + "	www.demowebsite.com"
(Get-Content -Path $hostsFile) -Replace "$stringToBeRemoved","" | Set-Content $hostsFile -Force
I have added the custom action as it follows:
- after the "Add resources" action group
- "Execution Time" set to "When the system is being modified (deferred)"
- "Execution Options" --> "Run under the LocalSystem account with full privileges (no impersonation)"
- "Execution Stage Condition" --> only "Uninstall" checked
Thank you for bringing this to my attention and hope this helps! :)
HienHo
Hello Catalin,
Wow, you’re a legend! Thank you heaps for your great help Catalin.
I am sure this article would be of big help to many users out there. Advanced Installer rocks!
Hien
You are always welcome, Hien!
It is always my pleasure to help and thank you very much for your kind words! :)
HienHo
One more thing, you mentioned one of the prerequisites was Advanced Installer enterprise version. So this solution won’t work on other versions? Thanks.
Hien
Hello Hien,
This article requires some features that are available starting with our Enterprise suite, therefore that is why I've mentioned it as a prerequisite.
This should work just fine in the Enterprise and Architect suites.
HienHo
Thank you Catalin for your confirm.
So I gather the Professional version won’t work. Time to upgrade. 😊
Hien
You are always welcome, Hien! :D
Return to “Sample Projects”
