alext72
Powershell Automation - Control Panel Icon
Currently trying to automate packages creation with powershell and the Advanced Installer com object.
Everything is fine but one thing is missing, the ability to define the control panel icon under Product Detail
I have created the project under "Architect mode"
$project = $advinst.CreateProjects("architect")
The only properties available for the object "$project.ProductDetails" are :
Name
ProductCode
Publisher
RegisterWithWindowsInstaller
UpgradeCode
Version
Am I missing something ?
Could it be a feature request ?
Cheers
Re: Powershell Automation - Control Panel Icon
Hello Alex,
Unfortunately, this is currently not possible through our PowerShell Automation support.
I have, however, added this on our TODO list of improvements and it will be added in a future version of Advanced Installer. Thank you for bringing this to our attention!
In the meantime, I believe you can use our command line support:
Set Control Panel Icon Command
alext72
Thanks, it's working great.
I'm also trying to create a shortcut under [ProgramMenuFolder][ProductName]
For Desktop folder i've followed the tutorial, referencing "desktopfolder"
$project.ShortcutsComponent.CreateFileShortcuts("desktopfolder", $exeFile.Fullpath))
What's the special word for [ProgramMenuFolder][ProductName] and how I can find the exhaustive list of folders ?
alext72
Also, since powershell doesn't have a control panel ico property, if I use the command line to set this property I can't build the project with the powershell build method. I must stick to the command line to also build the project. If it's builded with PS the icon is not displayed even if it's present in the aip file.
And if you plan to update powershell automation, it would be also great to be able to pass an ico file to the CreateFileShortcut method
https://www.advancedinstaller.com/user- ... onent.html
as it can be done via command line :
https://www.advancedinstaller.com/user- ... rtcut.html
Hello Alex,
You are always welcome!
I am glad it works as expected.
... how I can find the exhaustive list of folders?
You might find the "Paths of the folders in the Files and Folders page" article useful.
Regarding your request:
Please note that this is possible.
Later edit:
In addition to the article I've linked above, please note you can get a list of the predefined folders like this as well:
$advinst = new-object -comobject AdvancedInstaller
# load some project
$project = $advinst.LoadProject("path")
$project.PredefinedFolders.<here_you_can_surf_using_TAB>
# or you can simply enter $project.PredefinedFolders in the terminal and press Enter
This improvement (adding the Control Panel icon) has been added in Advanced Installer 18.2, released on April 23rd, 2021.
alext72
Catalin wrote: ↑Mon Apr 26, 2021 5:55 pm Hello,
Hello Catalin,
Thanks for the info. I'm currently running the Version 18.2 (DE2BF547).
How do you add the control panel icon info ?
The only sub properties available for the property .ProductDetails are :
.Name
.ProductCode
.Publisher
.RegisterWithWindowsInstaller
.UpgradeCode
.Version
I've not found the information in the documentation https://www.advancedinstaller.com/user- ... ation.html
Hello Alex,
Here is how you could set the icon:
$project = $advinst.loadproject("PATH_TO_PROJECT")
$project.ProductDetails.SetIcon("PATH_TO_ICON")
$project.save()
alext72
Thanks for your quick answer Catalin,
It works now, I was looking for a property rather than a method... My bad. :oops:
You are always welcome, Alex!
I am glad everything works as expected now. :)
