hitendamania
SQL Script did not Ran
Hi
I have create a package which has 2 connection in SQL, however on production environment it Ran the script only from one connection, for other connection it did not ran the script and gave installation successful.
Note: The installer was run in quite mode and was made using version 15.6. I have attach the API and Log for you reference.
What could be the issue?
ShipSure-2.0.27.193.Patch.aip
(38.8 KiB) Downloaded 217 times
PATCH_27_193_LOG.txt
Log
(256.32 KiB) Downloaded 261 times
Re: SQL Script did not Ran
Thank you for the provided resources.
I have investigated them, but unfortunately I was not able to find the culprit.
In order for me to further investigate this, could you please create a sample project that reproduces this issue and forward it to me so I can build and test it on my end?
